Surface plot blocked
Raimund
Post by Raimund » Thu Feb 17, 2022 12:59 pm
If you click with the left mouse button on the plot directly after creating a surfce plot, the entire graphic blocks.
I use TeeChart2022 and have not yet found a way to handle this. Interestingly, if you previously moved the chart with the right mouse button held down, this no longer happens.
I use surface plots in different programs (c++) in different ways. The described problem always occurs.
Does anyone have similar problems?
Raimund
