Map Chart - Country Highlight Color
JPTP
Post by JPTP » Wed May 10, 2017 6:07 am
Hi
When you mouse over a country in a map chart the country outline is highlighted. On my system this is an orange color. And the outline line thickness is probably 3 or 4 pixels. How can I change the color used for the outline and is it possible to use a thinner line?
Re: Map Chart - Country Highlight Color
Post by Yeray » Wed May 10, 2017 10:00 am
You can modify the Series Hover through the editor:
However, I'm afraid you can't do the same by code. I've added it tot he public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1858
JPTP
Post by JPTP » Wed May 10, 2017 11:04 am
Thanks Yeray. Does not seem to work for me. I change it as per your screenshot but it reverts when I look at the dialog in the screenshot again. WIll not change to the colour I set or the thickness.
I'm using WinDev 21.
Post by Yeray » Wed May 10, 2017 1:53 pm
What TeeChart ActiveX version are you using?
