vc example failed
leihj
vc example failed
Post by leihj » Wed Aug 24, 2011 9:35 am
I compiled the vc example you provided, and it occurs the following error:
Loaded 'C:\Windows\System32\clbcatq.dll', no matching symbolic information found.
VCExample: CoCreateInstance of OLE control {3F3E1E1C-81B6-4B11-84A5-25812A9491F6} failed.
VCExample: >>> Result code: 0x80040154
VCExample: >>> Is the control is properly registered?
VCExample: Warning: CreateDlgControls failed during dialog init.
But I have registed the teechart ocx control, is there anything I should to do? Thanks!
Candy
leihj
Re: vc example failed
Post by leihj » Wed Aug 24, 2011 9:38 am
My machine environment is windows server 2008,32bit , thanks!
Post by Yeray » Fri Aug 26, 2011 3:26 pm
Hello Candy,
Excuse us for the delayed reply.
Is the example you refer the one located here?
\Examples\Visual C++\Version 6\TeeChart palette components\VCExample.dsw
What TeeChart version are you using?
What IDE are you using?
I could compile and run it without problems here with TeeChart v2010.0.0.3 and Visual C++ 6
