Point mark when point is visible
Posted: Tue Nov 30, 2010 5:45 pm
by 15051059
Is there a way to make the mark of a point visible if and only if the point is visible on the graph?
- Label_Overrun.jpg (190.33 KiB) Viewed 8116 times
In the image above, the mark [357.5] still shows even when the point is no longer visible on the graph. I tried clipping; however, it clips the mark. What I want to do is to not show the mark if the point is no longer visible.
Re: Point mark when point is visible
Posted: Wed Dec 01, 2010 9:23 am
by narcis
Hi Raymond,
Have you tried clipping marks?
TChart1.Series(0).Marks.Clip = True
Posted: Wed Dec 01, 2010 4:35 pm
by 15051059
I tried that. The problem is it clips the marks. What I want to do is to not show the mark if the point is no longer visible on the graph. However, if the point is still visible, even though the mark will be off the graph, I still want to show the mark.
Posted: Fri Dec 03, 2010 10:25 am
by 10050769
Hello Rymond,
Ok. I made a simple code that uses method of series CalcYPos(i). I think you can use it for solve your problem with marks in your application. Moreover we can added it request in wish-list with number (TV52015303) to be enhanced for next releases.
TChart1.Aspect.View3D = False
TChart1.AddSeries scLine
TChart1.Series(0).FillSampleValues 25
TChart1.Series(0).Marks.Visible = True
Dim yPos As Integer
yPos = TChart1.Series(0).CalcYPos(i)
With TChart1.Series(0).Marks
If (yPos < TChart1.Axis.Left.IStartPos) Or (yPos > TChart1.Axis.Left.IEndPos) Then
.Item(i).Hide
Else
.Item(i).Show
End If
End With
Next
I hope will helps.
