Zoom Exceeds Frame
jacques
Zoom Exceeds Frame
Post by jacques » Tue Oct 13, 2009 9:00 am
I have created a surface plot, consisting of 20 by 100 elements.
The plot is displayed correctly. however when zooming the zoomed area is displyed outside of the axes, overwriting the x an y axis.
I have attached a Visual C++ (2008) example. Press plot palettes and then zoom to see the problem.
JB
test.zip
(490.95 KiB) Downloaded 497 times
Re: Zoom Exceeds Frame
Post by Yeray » Tue Oct 13, 2009 12:01 pm
Hi Jacques,
I can't run your application here as it uses some components we don't have here. So please, try to arrange a simple example project we can run as-is here to reproduce the problem.
jacques
Post by jacques » Fri Oct 16, 2009 11:56 am
Hello Yeray,
Which components are those?
JB
Post by Yeray » Mon Oct 19, 2009 11:09 am
Hi Jacques,
Excuse me, I hadn't the Visual C++ 2008 Feature Pack...
I've found that adding the following to the begin of your OnBnClickedBtnPlot3d, the problem seems to be solved:
m_colorGrid.ClearChart();
m_colorGrid.GetAspect().SetView3D(false);
That makes me think that I can be missing something else you've set to the chart. Then I'm trying to reproduce the same in a WinFroms application. Could you please see if you can reproduce the problem there and tell us what are we missing?
CAXTest.zip
Test WinForms
(9.47 KiB) Downloaded 442 times
