Bug 913 - Draw chart with transparency
Summary: Draw chart with transparency
Status: IN_PROGRESS
Version: 140512
Reported: 2014-09-08 09:02 EDT by yeray alonso
Modified: 2014-09-17 05:16 EDT (History)
Description yeray alonso 2014-09-08 09:02:02 EDT
PNG format supports true transparency, by specifying an alpha channel, as does the GDI+ bitmap.
Implement a way of specifying a transparency level for the tchart panel, which would be rendered properly to a format that supports transparency.
Comment 1 david berneda 2014-09-17 05:16:41 EDT
This is now possible, setting the Chart1.Color to either "clNone" or:
Chart1.Color := Chart1.Canvas.ColorFrom(0,255);  // 255 = full transparent
or equivalent:
Chart1.Color := $FF000000;
Note:
Its usually nicer a transparent chart with Chart1.BevelOuter := bvNone.
Also Chart1.Gradient.Visible:=False, otherwise the gradient will cover the whole chart and it will not be transparent.
Note:
VCL only, for versions prior to Delphi 2009, the project must be rebuilt using the special define "PNGIMAGE".
