Bug 816 - Pen seems to be still drawn in GDIPlus after setting to be inVisible
Summary: Pen seems to be still drawn in GDIPlus after setting to be inVisible
Version: 140512
Reported: 2014-06-26 08:16 EDT by yeray alonso
Modified: 2014-09-15 03:07 EDT (History)
Description yeray alonso 2014-06-26 08:16:03 EDT
In GDIPlus you can hide the Pen but it's still drawn in the majority of the lines.
In a TBarSeries it is more difficult to observe this because in vertical and horizontal lines it seems to work fine.
This happens in v2011.03 and up.
It didn't happen in v2010.01.
Haven't tried in v2010.02.
uses Series, TeCanvas;
var Chart1: TChart;
var i: Integer;
  Chart1:=TChart.Create(Self);
  Chart1.Parent:=Self;
  Chart1.Align:=alClient;
  with TTeeGDIPlus.Create(Self) do
    TeePanel:=Chart1;
    Active:=true;
  Chart1.Color:=clWhite;
  Chart1.Gradient.Visible:=false;
  with Chart1.AddSeries(TPieSeries) as TPieSeries do
    for i:=0 to 6 do
      Add(1, '', clBlack);
    Pen.Visible:=false;
    Shadow.Visible:=false;
    Circled:=true;
Comment 1 david berneda 2014-09-15 03:07:42 EDT
Pen.Visible is not the problem.
The pen is hidden, but the problem is GDI+ antialias, leaves one extra pixel at polygon (pie slice) right/bottom corner.  And the background appears.
This works fine:
    TeePanel:=Chart1;
    Active:=True;
    Antialias:=False;  <----- disable antialias
The solution is not easy.
Maybe using polygon-offset GDI+ api parameters.
