Bug 698 - axis increment strange when really smaller than the axis range
Summary: axis increment strange when really smaller than the axis range
Version: 140220
Assignee: yeray alonso
Reported: 2014-04-04 09:34 EDT by yeray alonso
Modified: 2023-01-11 09:28 EST (History)
axis increments (1.50 KB, application/octet-stream)
2014-04-04 09:34 EDT, yeray alonso
Description yeray alonso 2014-04-04 09:34:44 EDT
Created attachment 150 [details]
axis increments
Axis increment strange when really smaller than the axis range.
Look at the application attached.
With the actual sources, in a Large Data Range, if you set:
- 0.1 increment for the bottom axis, you get 0.8 increments (labels at 0, 0.8, 1.6,...)
- 0.01 increment for the bottom axis, you get 0.64 increments (labels at 0, 0.64, 1.28,...)
- 0.001 increment for the bottom axis, you get 1.024 increments (labels at 0, 1.1024, 2.048,...)
Is that the expected result? It looks strange.
In v2013.08, the same application shows 0.5 increments (labels at 0, 0.5, 1,...) in the bottom axis when you set either 0.1, 0.01 or 0.001 increments.
Comment 1 Bruce 2022-12-19 04:33:22 EST
Still an actual bug.
Comment 2 Bruce 2022-12-19 04:40:15 EST
Tried to set an axis increment to avoid duplicate labels when zooming too much, but this setting doesn't work properly, just added another problem.
Comment 3 yeray alonso 2023-01-10 03:45:21 EST
The `TChartAxis.CalcLabelsIncrement` function calculates the final increment considering the `Increment` property, the axis range, etc. It was doing multiple attempts in a *2 basis which wasn't accurate enough for some situations. We've changed it for a *0.2 basis.
Also note you can use `OnBeforeDrawAxes` event to manually set the axis `Increment` considering the actual axis range. Ie:
procedure TForm1.Chart1BeforeDrawAxes(Sender: TObject);
  if (Chart1.Axes.Bottom.Maximum - Chart1.Axes.Bottom.Minimum) < 0.02 then
    Chart1.Axes.Bottom.Increment := 0.001
  else if (Chart1.Axes.Bottom.Maximum - Chart1.Axes.Bottom.Minimum) < 0.2 then
    Chart1.Axes.Bottom.Increment := 0.01
  else if (Chart1.Axes.Bottom.Maximum - Chart1.Axes.Bottom.Minimum) < 2 then
    Chart1.Axes.Bottom.Increment := 0.1;
Comment 4 Bruce 2023-01-10 10:40:15 EST
The proposed workaround solves the problem of duplicates, but it also breaks the increment in the way you described it above in 2014. In my project I get axis increments 0, 8.192, 16.384, 24.576, ... instead of 0, 10, 20, ... when I don't use suggested code snippet.
Comment 5 yeray alonso 2023-01-11 04:44:26 EST
Indeed it doesn't work as it did in v2013.08, but I think it's more coherent now.
If you set an increment of 0.001, it makes sense that 0.477 is tested before testing 0.5.
Comment 6 Bruce 2023-01-11 09:28:48 EST
(In reply to yeray alonso from comment #5)
> now.
> testing 0.5.
So how do you set the increments to always get "nice" labels while avoiding duplicates, as it used to be?
