Bug 680 - [TV52016031] If you try to export a VCL Chart to a tee file and import it in a FMX...
Summary: [TV52016031] If you try to export a VCL Chart to a tee file and import it in ...
Reported: 2012-02-10 16:59 EST by yeray alonso
Modified: 2014-03-28 06:54 EDT (History)
Description yeray alonso 2014-03-28 06:54:30 EDT
If you try to export a VCL Chart to a tee file and import it in a FMX Chart, it can crash for some properties that are different.
I see two alternatives:
- Make an application similar to TeeToTen to convert a given tee file created from a VCL application. This program would check if each property exists in TeeChart FMX and correct or discard the problematic ones
- LoadChartfromFile could do the same check&correction process than the separate application.
http://www.teechart.net/support/viewtopic.php?f=17&t=12981 [created:2012-02-10T16:59:58.000+01:00 reported by:yeray@steema.com reported in version:2011.04.41118 (TeeChart VCL)]
