Bug 562 - Bad shadow rendering with Metafile export in GDI+
Summary: Bad shadow rendering with Metafile export in GDI+
Status: IN_PROGRESS
: High normal
Reported: 2014-02-06 11:17 EST by narcís calvet
Modified: 2014-02-07 03:00 EST (History)
Description narcís calvet 2014-02-06 11:17:16 EST
Shadows are not rendered correctly when exporting to a Metafile image in GDI+ canvas. Works fine in GDI. To reproduce drop a TImage and TChart components to a form and use this code:
uses Series, TeCanvas;
  Chart1.AddSeries(TPieSeries.Create(Self)).FillSampleValues;
  //Chart1.Canvas:=TTeeCanvas3D.Create; //GDI canvas works fine
  Image1.Picture.Graphic := Chart1.TeeCreateMetafile(True, Rect(0, 0, Chart1.Width, Chart1.Height));
Comment 1 david berneda 2014-02-06 12:34:41 EST
Fixed. The problem is GDI+ draws shadows are displayed using semi-transparent colors to obtain a "smooth" shadow effect.  This semi-transparent colors are converted to Metafiles as "brush patterns".
Pending to investigate how to convert our metafiles from Enhanced to Enhanced Plus.
Enhanced Plus (GDI+ only) metafiles should support both antialiasing and semi-transparent colors without patterns.
Comment 2 narcís calvet 2014-02-07 03:00:52 EST
Workaround are either using the GDI canvas for the export:
uses VCLTee.TeCanvas;
procedure TForm1.Button1Click(Sender: TObject); begin
  Chart1.Canvas:=TGDIPlusCanvas.Create;
Or hiding all shadows:
  Series1.Shadow.Visible:=False;
  Series1.Marks.Shadow.Visible:=False;
  Chart1.Legend.Shadow.Visible:=False;
  Chart1.Legend.Symbol.Shadow.Visible:=False;
  Image1.Picture.Graphic := Chart1.TeeCreateMetafile(True, Rect(0, 0, Chart1.Width, Chart1.Height)); end;
