Bug 52 - If you remove the SeriesStats tool it doesn't remove the extra Series that is added in chart.
Summary: If you remove the SeriesStats tool it doesn't remove the extra Series that is...
Reported: 2013-10-23 11:20 EDT by sandra pazos
Modified: 2013-11-18 09:25 EST (History)
Description sandra pazos 2013-10-23 11:20:24 EDT
When you work with Bar Series with SeriesStats tool and mark the Average, a BarSeries is added to the Series tab in Chart Editor, too. It isn't behaved the same way in TeeChartActivex. I have added the same enhancement to Activex product with number[] to achieve the both behave equals.
Comment 1 sandra pazos 2013-10-23 11:27:51 EDT
Modify:When you work with Bar Series with SeriesStats tool and mark the Average, a BarSeries is added to the Series tab in Chart Editor, too. It isn't behaved the same way in TeeChartActivex. I have added the same enhancement to Activex product with number[53] to achieve the both behave equals.
Comment 2 sandra pazos 2013-11-18 09:24:49 EST
The previous bug explanations is incorrect, so I have detected in the message lacks information.
If you work at the same time with a Standard Series and a SeriesStats tool, when you mark the average function of Statistics tool, one extra series (function average) is added to the Series tab in Chart Editor, too.  After, if you remove the tool, the extra Series isn't removed from the Chart. The same problem occurs in TeeChartVCL, bug number [id106].
To reproduce the problem you only need following next steps in Design-Time or Run- Time:
1.- Add Chart in the Form.
2.- Open editor, Add Series and Add Statistics tool.
3.- In Statistic tool check the Average function.
One extra series is added in the Chart and in the Series Editor Chart.
4.- Remove the  Statistics tool.
6.- Close Editor.
The extra Series isn't removed from the Chart.
