Bug 328 - [TV52015479] If I fill the series with min and max set to 0 (and no automatic scal...
Summary: [TV52015479] If I fill the series with min and max set to 0 (and no automatic...
Reported: 2011-04-06 13:55 EDT by narcís calvet
Modified: 2013-11-20 10:38 EST (History)
Description narcís calvet 2013-11-20 10:38:46 EST
If I fill the series with min and max set to 0 (and no automatic scale of the axis), the application hangs. You should press the button in the test application attached, and then quickly try to resize the application form. On Windows 7 x64 it hangs the entire system. The applicaiton CPU usage increases and can not  be killed. You need to restart the system. Works fine in x86 environments. [created:2011-04-06T12:55:46.000+01:00 reported by:narcis@steema.com reported in version:2010.02.20202 (TeeChart VCL)]
