Bug 28 - Gauges Series example demo
Summary: Gauges Series example demo
Reported: 2013-10-17 12:03 EDT by sandra pazos
Modified: 2014-03-18 12:44 EDT (History)
Description sandra pazos 2013-10-17 12:03:38 EDT
I think the items in the Style collection are incorrect. For example, if I click the Edit -> Hand button and try to select one of the styles from the Style dropdown list, there are 20 styles listed (starting from Square to ColorLine).
Also, please check the styles in the Palettes. The items below MacOS don't work.
To check the problems see the example demo All Features\Welcome !\Chart styles\Gauges
Comment 1 christopher ireland 2013-12-04 12:49:51 EST
Not sure exactly what the problems are, but "a simple vista" everything works okay with the latest code.
Comment 2 Shinobu Nagai 2014-02-18 21:01:22 EST
They aren't fixed yet with v4.1.2014.02060.
Re. Hand style:
Please run the DemoProject, go to All Features\Welcome !\Chart styles\Gauges\CircularGauge, clik the "Edit" and then "Hand" buttons.
Some hand styles in the dropdown list, such as Star, ColorLine, Dot, Hexagon, etc., don't work (invisible).
Re. Palettes:
If I select each Palette style from the dropdown list in ascending order, I confirmed the ones from "Current" to "MacOS" worked fine, but not below "MacOS".
Comment 3 Shinobu Nagai 2014-02-19 21:33:49 EST
Let me make sure about the status.
The current status of these issues are "CONFIRMED", aren't they?
In the History page, it says WORKSFORME, but they don't work at our end.
Comment 4 Shinobu Nagai 2014-03-18 01:44:27 EDT
As for What's New?\Welcome!\New in Series\Gauges\Embedded NGauge,
please follow the steps to reproduce a problem.
1. Opens Chart Editor.
2. Goes to Series -> Format -> Option tab.
3. Clicks the "Center" button.
4. Changes the pointer style to "Sphere" and closes Chart Editor.
While the hand is moving, the afterimage of the hand remains.
Comment 5 sandra pazos 2014-03-18 12:44:54 EDT
Hello Nagai,
I would inform you, I have created a new defect with your last comment, as you can see in the link, http://bugs.teechart.net/show_bug.cgi?id=648, because the issue is different than this bug that is already confirmed
Thanks in advance,
