Bug 275 - [TV52016009] A customer made me notice the axis labels behaviour has changed many ...
Summary: [TV52016009] A customer made me notice the axis labels behaviour has changed ...
Reported: 2012-01-19 12:35 EST by yeray alonso
Description yeray alonso 2013-11-20 10:35:52 EST
A customer made me notice the axis labels behaviour has changed many times in v2010-2011 when you have two series with labels.
http://www.teechart.net/support/viewtopic.php?f=3&t=12958
The code below produces overlapping axis labels in v2010.01 and in v2011.04
However, it shows correct axis labels in v2010.00, v2010.02 and v2011.03
So it was broken in v2010.01, fixed in v2010.02 and broken again in v2011.04.
uses Series;
var i: Integer;
  Chart1.AddSeries(TFastLineSeries);
  for i:=0 to 49 do
    Chart1[0].AddXY(i, random, IntToStr(Chart1[0].Count));
    if i mod 5 = 0 then
      Chart1[1].AddXY(i+0.2, random, IntToStr(Chart1[1].Count));
I've seen tha last time it changed was with TeEngine.pas revision 1.160. As explained in the commentary, the change was to fix the case:
  Chart1[0].AddXY(1, 2, 'test1');
  Chart1[0].AddXY(2, 3, 'test2');
  Chart1[1].AddXY(0, 2, 'test0');
  Chart1[1].AddXY(1, 3, 'test3');
And it really seems the two problems are related because in the releases where the first problem is reproducible, the second problem isn't. And viceversa. [created:2012-01-19T12:35:30.000+01:00 reported by:yeray@steema.com reported in version:2011.04.41118 (TeeChart VCL)]
