Bug 2702 - Bug on the apply button of a Summary
Summary: Bug on the apply button of a Summary
Product: FireMonkey TeeChart
Version: 40.240410
Assignee: yeray alonso
Reported: 2024-05-06 05:58 EDT by yeray alonso
Modified: 2024-05-06 06:29 EDT (History)
Description yeray alonso 2024-05-06 05:58:56 EDT
From the customer:
Bug on the apply button of a Summary, after having set the field and clicked on apply, if I change the field the apply remains disabled, to resolve it you need to change the Calculate (The apply button instead works correctly in the case of DataSource/Dataset).
See the screenshot from the customer:
https://www.steema.com/support/download/file.php?id=8975
An example, using a button to open the editor.
Use it to select "Summary" as the DataSource.
Select "MyTable" as the Dataset, and "Calculate" "Sum" of "Increasing".
Press "Apply".
Change the "of" filed to "Decreasing".
Note you can't press the "Apply" button.
uses Chart, DBChart, Editor.Chart, Editor.DBChart, Series, Engine,
FireDAC.Comp.Client, Data.DB;
var BarChart: TDBChart;
var MemTable1: TFDMemTable;
procedure TForm1.EditBarButtonClick(Sender: TObject);
  TChartEditForm.Edit(Self, BarChart);
var val: double;
    i: Integer;
  MemTable1:=TFDMemTable.Create(Self);
  with MemTable1 do
    FieldDefs.Add('Increasing', ftInteger);
    FieldDefs.Add('Decreasing', ftInteger);
    CreateDataSet;
    Open;
    AppendRecord([10, 100]);
    AppendRecord([20, 90]);
    AppendRecord([30, 80]);
    AppendRecord([40, 70]);
  BarChart:=TDBChart.Create(Self);
  with BarChart do
    Parent:=Self;
    Align:=TAlignLayout.Client;
    Color:=TAlphaColors.White;
    Gradient.Visible:=False;
    Walls.Back.Color:=TAlphaColors.White;
    Legend.Hide;
    with AddSeries(TBarSeries) do
      Marks.Hide;
      ColorEachPoint:=True;
