Bug 2621 - Add an event to modify properties when saving the chart to Stream/File
Summary: Add an event to modify properties when saving the chart to Stream/File
Status: RESOLVED WONTFIX
Reported: 2023-07-13 12:12 EDT by yeray alonso
Modified: 2023-07-14 02:44 EDT (History)
test example (1.80 KB, application/x-zip-compressed)
2023-07-13 12:12 EDT, yeray alonso
Description yeray alonso 2023-07-13 12:12:18 EDT
Created attachment 1050 [details]
test example
It could be sometimes useful to allow modifying the properties that are being saved to a Stream, as the customer in the forums suggests.
I've added the customers test project with the event - under development - commented out.
Comment 1 yeray alonso 2023-07-14 02:44:52 EDT
The latest version (v2023.38) adds SaveChartToString/LoadChartFromString which could do the job without having to add a new event into the Chart. Here the example:
procedure TForm1.BSaveClick(Sender: TObject);
var lStringList:TStringList;
  procedure DeleteIfExists(prop: string);
  var idx: Integer;
    idx:=lStringList.IndexOf(prop);
    if idx>=0 then
       lStringList.Delete(idx);
  lStringList:=TStringList.Create;
  lStringList.Text:=SaveChartToString(Chart1);
  DeleteIfExists('Marks.OnTop');
  MemoXML.Lines:=lStringList;
procedure TForm1.BLoadClick(Sender: TObject);
  LoadChartFromString(Chart1, MemoXML.Lines.Text);
