Bug 2577 - Invalid axis tick label dimensions
Summary: Invalid axis tick label dimensions
Status: RESOLVED DUPLICATE of bug 2588
Version: 34.220203
Reported: 2022-12-15 08:53 EST by Andrew
Modified: 2023-03-15 06:31 EDT (History)
Chart Series: FastLine
Delphi / C++ Builder RAD IDE Version: RAD 11 Alexandria
Screenshots (2.69 KB, application/x-zip-compressed)
2022-12-15 08:53 EST, Andrew
Description Andrew 2022-12-15 08:53:23 EST
Created attachment 1028 [details]
Screenshots
We have a series that has the same Y values of all points and have a long fractional part.
The chart for calculating the size of the axis's labels uses rounding to some value.
In the case of equal values, rounding up to (1) occurs, and for the value of (12.345) the size of the label "12" instead of "12.345" will be calculated.
We found in the code that causes such behavior, and there is already a comment with a possible solution:
VCLTee.TeEngine:4347 (InternalCalcLabelsIncrement)
if IRangeZero then
         result:=1 // <-- TODO: What can we use instead of 1? A magnitude of Min?
Please check this issue
The second attachment file is a screenshot after local fix as proposed in comment
Comment 1 yeray alonso 2023-03-15 06:31:52 EDT
*** This bug has been marked as a duplicate of bug 2588 ***
