Bug 2493 - Dragging a component over a chart doesn't show the icon of the operation set at DragOver event
Summary: Dragging a component over a chart doesn't show the icon of the operation set ...
Product: FireMonkey TeeChart
Version: 33.210915
Assignee: yeray alonso
Reported: 2021-12-15 17:12 EST by yeray alonso
Modified: 2021-12-15 17:12 EST (History)
Description yeray alonso 2021-12-15 17:12:34 EST
As the customer says in the forums:
> In the DragOver event, if you set the operation, it does not reflect the operation of the drag/drop. For example, setting it to TDragOperation.None should result it the "not accept" icon.
> I can see in the FMXTee.Chart code, procedure TCustomChart.DragOver, the Operation is ignored. Clearly we are trying to make this work the VCK version which only has 2 states.
> Fix:
> the line that says: tmpB:=True;
> should read: tmpB := Operation <> TDragOperation.None;
> and then after the broadcast, the line that says: if tmpB then Operation:=TDragOperation.Move;
> should read: if not tmpB then Operation:=TDragOperation.None;
To reproduce the issue, add a TChart and a TImage in a new form. Set the TImage DragMode to dmAutomatic and set the TChart OnDragOver event:
procedure TForm1.Chart1DragOver(Sender: TObject; const Data: TDragObject;
  const Point: TPointF; var Operation: TDragOperation);
Now try to drag the TImage over the TChart
