Bug 235 - [TV52016358] There seem to be some inconsistences with the Gauges editors. The fo...
Summary: [TV52016358] There seem to be some inconsistences with the Gauges editors. Th...
Reported: 2012-09-25 12:44 EDT by yeray alonso
Modified: 2013-11-20 10:33 EST (History)
Description yeray alonso 2013-11-20 10:33:49 EST
The following seems to work fine in a new empty chart with a commander to get access to the editor at runtime:
- Run the application and open the editor.
- Add a Linear Gauge.
- Go back to the series list "Chart/Series" and remove the Linear Gauge.
- Add a Circular Gauge.
- Go to the "Series/Format" tab.
However, adding just an step, makes the problem to appear:
- Go to the "Series/Format" tab. There's no subtab!
Also note the same happens in the reverse order: if you add the Circular Gauge first, go to the series/format tab, change the series for a Linear Gauge and go to the series/format tab.
It also happens with Linear Gauge and Vertical Gauge.
http://www.teechart.net/directline/viewtopic.php?f=4&t=729 [created:2012-09-25T11:44:12.000+01:00 reported by:yeray@steema.com reported in version:2012.06.120613 (TeeChart VCL)]
