Bug 229 - [TV52016405] Problem with Area Series SubGrandient. If you add and area series a...
Summary: [TV52016405] Problem with Area Series SubGrandient. If you add and area seri...
Reported: 2012-11-09 17:33 EST by sandra pazos
Modified: 2013-11-20 10:33 EST (History)
Description sandra pazos 2013-11-20 10:33:32 EST
PProblem with SubGrandient editor.
If you add an area series and you want see the SubGradient appears some problems:
1.- The subgradient that change is the subgradient os Chart Panel. To check the problem you can do next:
1.- Add new chart in Form, add area series in Chart, add TeeCommander and Run project.
2.- Open the editor.
3.- Go to Series tab\Gradient active it and after go to SubGradient tab.
4.- Change for example transparency. You can see the changes are in the Panel.
2.- Button Edit of SubGradient doesn't works.
To reproduce it only need try to change properties of SubGradient of editor SubGradient.
Finally, I think that the button Edit have an incorrect behavior, so if you click in edit button, it open the subgradient editor, it allows you change the subgradient. If you select SubGradient tab appears again  the Subgradient editor, thus every time you click edit button a new subgradient chart appear. I think this have and incorrect behavior that causes confusion to clients and break the Subgradient editor, too.  [created:2012-11-09T17:33:06.000+01:00 reported by:sandra@steema.com reported in version:]
