Bug 1576 - [TV52015721] If you order the values by Text (ascending or descending), when you o...
Summary: [TV52015721] If you order the values by Text (ascending or descending), when ...
Reported: 2011-09-05 10:16 EDT by yeray alonso
Modified: 2016-07-08 11:02 EDT (History)
Description yeray alonso 2016-07-08 11:02:31 EDT
If you order the values by Text (ascending or descending), when you open the editor Series/General, the two "Sort" comboboxes (CBSortBy and CBSortOrder in TeeEdiSeri.pas) don't reflect your configuration.
For example, having this series and values:
uses Series;
  with Chart1.AddSeries(TBarSeries) as TBarSeries do
    Add(100, 'AB');
    Add(100, 'AA');
    Add(100, 'BB');
    Add(100, 'BA');
If you set Text descending order by any of the following options:
1. call SortByLabels(loDescending) at runtime.
2. navigate through Series/General and select Text in the first "Sort" combobox and Descending in the second "Sort" combobox. Close the editor.
If you open the editor "Series/General", it still shows "X" and "Ascending" in the comboboxes. [created:2011-09-05T10:16:38.000+02:00 reported by:yeray reported in version:2011.03.30407 (TeeChart VCL)]
