Bug 143 - [TV52012815] If the Y axis of a chart is limited (to 100 for example) and the char...
Summary: [TV52012815] If the Y axis of a chart is limited (to 100 for example) and the...
Reported: 2008-02-14 12:43 EST by narcís calvet
Modified: 2013-11-20 10:00 EST (History)
Description narcís calvet 2013-11-20 10:00:02 EST
If the Y axis of a chart is limited (to 100 for example) and the chart content (ie bars) exceeds the Y axis upper limit (to 140 for example), the PDF output will paint the bars above the chart and into the margin area.
On the screen canvas, the bars are capped at the Y axis limit where on the PDF canvas they are not.
To recreate. I used a stacked bar chart with automatic Y scaling. Reset the Y scaling and set the Y Max value to less than one of the bar maximums. When the screen canvas is drawn, some of the bars will be "capped". When the output of the chart is directed to the PDF format, the bars will not be capped.
See attached project and pdf document reproducing this. [created:2008-02-14T12:43:32.000+01:00 reported by:narcis@steema.com reported in version:8.01 (TeeChart VCL)]
