Bug 138 - [TV52011998] Instructions for duplicating the problems with attached project --...
Summary: [TV52011998] Instructions for duplicating the problems with attached project ...
Reported: 2007-01-02 10:32 EST by narcís calvet
Modified: 2013-11-20 09:59 EST (History)
Description narcís calvet 2013-11-20 09:59:46 EST
--------------- First Problem
1. Build the code.
2. Run the program.
3. On the Tchart Editor Tree, select "Series1".
4. On the Data Source tab, selection random from the combo box and then select the Apply button.
5. On the Editor Tree, select "Series".
6. on the display, select the "Add" button.
7. Select the Functions / Financial / Exp. Moving Average.
8. Select the "Ok" button.
9. On the Editor Tre, select "Series2".
10. On the Data Source tab and the Source Series tab, select "Series1" in the Series combo box.
11. Select the "Apply" button, -- NOTHING HAPPENS -- first problem.
--------------- Second problem
1. Repeat steps 1 through 10 --- "DO NOT SELECT THE 'APPLY' BUTTON"
2. In the Editor Tree, select "Series1".
3. Dialog "Apply Changes?" will appear.
4. Select "Yes" --- program will get an exception "Control 'TabSeries' has not parent window".
You will continue to get this error until you select the "Series" node in the Editor Tree. After one more error, all is working correctly -- you can set the series in "Series2", hit the "Apply" button, and you have the moving average line. [created:2007-01-02T10:32:18.000+01:00 reported by:narcis@steema.com reported in version:8.0 (TeeChart VCL)]
