Bug 1300 - Axis Texts.Position not persistent
Summary: Axis Texts.Position not persistent
Version: 150420
Reported: 2015-09-11 07:16 EDT by Bert Kreisel
Modified: 2015-09-18 09:21 EDT (History)
Description Bert Kreisel 2015-09-11 07:16:47 EDT
Value of Axis.Texts.Position is not saved to tee file
Comment 1 sandra pazos 2015-09-18 07:07:59 EDT
Hello Bert Kreisel,
Using the code below with latest TeeChart Pro VCL/FMX build number 2015.16.150901, the problem you are experiencing doesn't occur.
uses TeeExport,TeeStore,TeCanvas;
var Series1:TLineSeries;
Series1 :=TLineSeries.Create(self);
Chart1.AddSeries(Series1);
Series1.FillSampleValues(10);
Chart1.Axes.Left.Title.Visible := true;
Chart1.Axes.Left.Title.Text := 'Axis Left';
Chart1.Axes.Left.Title.TextAlignment := taLeftJustify;
Chart1.Axes.Left.Title.Position := tpCenter;
SaveChartToFile(TCustomChart(Chart1),ExtractFilePath(ParamStr(0))+'\ChartAxisPosition.tee');
Chart1.ClearChart;
LoadChartfromFile(TCustomChart(Chart1),ExtractFilePath(ParamStr(0))+'\ChartAxisPosition.tee');
I would like suggest you update your TeeChart Pro version to latest and check again if the problem you are experiencing appears for you. If the problem appears, please change the code above, so, we can reproduce it here.
Thanks in advance
Regards.
Comment 2 Bert Kreisel 2015-09-18 07:55:56 EDT
Hello Sandra,
please use texts.position and not title!
Chart1.Axes.Left.Texts.Position := lpBeforeTick;
Chart1.ClearChart;
Thanks in advance
Regards.
Comment 3 sandra pazos 2015-09-18 09:21:31 EDT
Hello Bert,
Sorry! I have checked it again and I confirm it is a bug.
