Bug 1272 - Force Label at beginning of Axis irrespective of Increment limitations
Summary: Force Label at beginning of Axis irrespective of Increment limitations
Reported: 2015-08-17 06:28 EDT by marc meumann
Modified: 2015-08-17 06:28 EDT (History)
Description marc meumann 2015-08-17 06:28:08 EDT
The OnAxis property enables/disables first/last Axis label for regularly incremented labels. This is something slightly different....
To oblige the placement of a first label, to coincide with the minimum axis value, irrespective of it's validity in relation to the Axis' own increment settings.
Effect can be seen with this workaround code:
using Steema.TeeChart;
using System.Reflection;
private void tChart1_AfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
    //set x position for new label
    int x = tChart1.Axes.Bottom.CalcPosValue(tChart1.Axes.Bottom.Minimum);
    //tChart1.Axes.Bottom.Labels.position (here the Label y coordinate) is protected so need alternative technique for y...
    AxisLabels tmpLabels = new AxisLabels(tChart1.Axes.Bottom);
    FieldInfo privateField = tmpLabels.GetType().GetField("position", BindingFlags.NonPublic | BindingFlags.Instance);
    int y = (int)privateField.GetValue(tChart1.Axes.Bottom.Labels);
    string label = tChart1.Axes.Bottom.Minimum.ToString("#");
    //output text
    g.TextOut(x - ((int)Math.Round(g.TextWidth(label) / 2)), y, label);
