Bug 1054 - Hidden Series are visible in PDF export
Summary: Hidden Series are visible in PDF export
Version: 140923
Reported: 2014-12-19 04:21 EST by Bert Kreisel
Modified: 2015-05-13 12:08 EDT (History)
Chart Series: Line
Description Bert Kreisel 2014-12-19 04:21:06 EST
A Line series with Transparency = 100 is visible in PDF export.
It is also visible in Metafile export if using GDI (GDI+ is ok).
Exported Bitmap, GIF, JPEG, PNG are always OK.
Comment 1 sandra pazos 2014-12-22 11:21:54 EST
I suspect the problem can be related by bug number 135. Here's the bug link http://bugs.teechart.net/show_bug.cgi?id=135
Comment 2 david berneda 2015-05-13 12:08:13 EDT
PDF format does not allow transparency in colors, only as overload layers (which we can't easily do).
A workaround could be considering a Transparency of 100 the same as the Pen being invisible (at PDF Canvas)
